I'm struggling with how to make a roof ridge that is not horizontal. I'm just beginning this BIM model and will naturally be working on it for the next 2-3 years so the solution has to be practical in terms of future skylight, sections...
Your roof pivot lines need to form a trapezium shape, that is the only way you will make that shape, without splitting that triangle in to two triangles or twisting the roof in to a curved shape.
Mostly AC 26 on Mac | Author of SelfGDL | Developer of the GDL plugin for Sublime Text | «Furthermore, I consider that Carth... yearly releases must be destroyed»
I was hoping there would be a solution where I could use the multi-plane roof, and easily adjust the angles as the project develop. It seems I have to use single-plane roofs, which is OK, but a bit more work...
Unfortunately the moment the footprint becomes something else than a rectangle the top ridge point is un-movable? That is very inconveniant at such an early stage...but probably because of geometry constraints.
