Not responding after publishing completes
Llian
I keep having to force quite at the end of the publishing ends. The wheel keeps spinning after I clicked close at the end of the publishing. I have reinstalled - repaired and still the same issue. Any thoughts?
Lilian Seow
LEED AP | cSBA
Interior-Architecture and BIM Management
AC20 USA | 27- macOS 10.14.6| 4 GHz Intel Core i7| 32 GB RAM | Archicad-user since 1994!
Eduardo Rolon
If you are publishing to a Network share, try publishing to a local folder. It might not be AC it could be your OS.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Llian
Thanks Eduardo.
It is save into my own local desktop folder. The strange thing is the published set is good in the folder. The issue is that AC freezes and I have to force quit each time after each publishing is done.
Lilian Seow
LEED AP | cSBA
