Object's surface painter override bug
NandoMogollon
Hi All,
Have any of you experienced or be able to replicate this bug?:
  • Use objects - say a window
  • Use the Surface painter and override the frame surface.
  • Then go and change anything... something not relevant, like the ID
  • BUG shows up: Surface override get's eliminated and the surface goes back to the previous (default ?) surface
Check the video
Nando Mogollon
Director @ BuilDigital
nando@buildigital.com.au
Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
6 REPLIES 6
Interesting. I will report this to Graphisoft.
Minh Nguyen
Dear Nando,
Thank you very much for the report and I am very sorry about the issue!
I tried to replicate the issue using Archicad 24 INT 6004, but it works correctly in my case. May I ask which Archicad language version you use, and did the issue happen with the latest update installed?
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Thanks Nguyen,
I just tried again, and can replicate in:
  • AC23 7000 AUS Full
  • AC24 6004 AUS Full
  • AC25 3002 AUS Full
Hope that helps
Nando Mogollon
Minh Nguyen
Hi Nando,
Thank you very much for the information! This is very helpful!
I found that, with the default AUS template, the option Uniform Window Surfaces is enabled. This is the reason why the surface got changed when you set the ID. Seems like this attribute was "reset" to match with the other surfaces set in its settings. Thus, the workaround in this case is to disable Uniform Window Surfaces option
I believe this is a bug, so I will enter it into our defect database. Thank you very much for the report once again, and have a great day!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
Behaves like a bug: it actually only happens once with objects, next time - and if you switch on/off the "Uniform Surfaces" options, then it won't happen again.
Regards
Nando Mogollon
Dear Nando,
Thank you very much for your finding! I have added it into our defect entry (please refer to it as DEF-6510).
I wish you a great day!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
