Design forum
Objects and Rotation
gdford
Is there a darn good reason out there to explain that when i create a new object, we still do not have a built in ability to rotate the object in any direction? Seriously - I really want to know why after a 1000 years we still can not rotate custom objects in any direction.  When I bring in a revit object into Archicad it comes in with the ability to rotate in all directions - what's up with that???.
Yes I know we can add GDL to make this happen....
just saying ....
Gary Ford
Self Employed - Modeling, Estimating, Construction
Archicad 12-25
AMD Ryzen 9 5900X 12-Core Processor
3701 Mhz, 12 Core(s), 24 Logical Processor(s)
(RAM) 128 GB
NVIDIA RTX A2000
3 parameters and 3 lines of code
Parameters all angles
Xr
Yr
Zr
3d script
Rotx Xr
Roty Yr
Rotx Zr
Change 2d script to a projection. And this is the likely reason it's not a default. 2d scripts are much harder to get to match the 3d rotation with out projection. Which ultimately can make things slow, although that's almost a thing of the past with today's hardware.
I'm guessing the import function for Revit does just this
FREE Soffit & Fascia for Rail Tool - https://bit.ly/BIMRithmSoffitandFascia
FREE wall Accessory framing and coverings - bit.ly/BIMRithmWallAccessories
FREE Truss object - https://bit.ly/BIMRithmTrussV1
FREE Custom Tube Object - https://bit.ly/BIMRithmPolyTube
AC 24, Twinmotion current, Windows 11, Msi 10UG with rtx 3070, wacom intuos pro m, Wacom Cintiq Pro 16, razer Tartarus pro.
Yes i know I can add code to my custom GDL objects, but i have about thirty objects and it really just pisses me off that Graphisoft has not been proactive for the last 1000 years and made this happen automatically.
Gary Ford
Archicad 12-25
(RAM) 128 GB
NVIDIA RTX A2000
zaIT
I totally agree because this one command makes Archicad looks ridiculously stupid to a new user who has been using other 3D softwares. This should be automatically coded in.
Didn't find the answer? Start a new discussion
Labels
