2005-01-0305:22 AM - last edited on 2023-05-2305:23 PM by Rubia Torres
In Archicad 9 how do you get a column's cross-section to appear on multiple stories? I created the object on Story 1 that rises through Story 4, but I can't get it to appear on the upper stories. This seems like an easy one but I'm stumped! THANKS
If you want something to show up an a story, it should (typically) belong to that story. So you should effectively 'stack' columns on top of each other - one on each story rising the height of it's respective story.
... you should (mostly) model the building the way it would be built. This is the most effective way to get consistent construction drawings.
Most columns are constructed one lift at a time. Model them one floor at a time. Copy-pasting between floors is very very quick so you shouldn't view this as a hassle.
If you have an atrium-type space then yes - here is a special issue. Do a search on "multiple stories" and you'll find the previous threads on this.
