2013-02-20 06:41 AM
2013-02-20 05:34 PM
2013-02-20 05:41 PM
2013-02-21 12:25 AM
Dwight wrote:Only my curiosity. I wonder if I know how to use this tool correctly.
BTW: What's the point of doing so?
2013-02-21 10:57 AM
2013-02-22 06:12 AM
Karl wrote:Karl:
Whether one or two, the advantage of using the new multiplane roof vs modeling the illustrated roof with old single plane roofs is not just the added editing intelligence (more so with one roof - as things will remain connected without additional work) - but that scheduling can show more data. For example, if there are ridge vents on those roofs, the multiplane roof can schedule the ridge length. Or, fascia length, etc. None of that is possible with the old single plane roofs.
2013-02-22 09:11 AM
David wrote:Yes - the ridges are doubled up with single plane roofs. Suppose you have a few shed roofs and a few gables ... all of the gables will be doubled. With the multiplane roof for the gable, the ridge is the correct ridge - for the vent for that ID'd roof, or the correct total for all roofs.
The edges of Single-plane Roofs can be assigned and scheduled, or were you referring something else?
2013-02-23 05:59 AM
Karl wrote:Karl:
Yes - the ridges are doubled up with single plane roofs. Suppose you have a few shed roofs and a few gables ... all of the gables will be doubled. With the multiplane roof for the gable, the ridge is the correct ridge - for the vent for that ID'd roof, or the correct total for all roofs.🙂
2013-02-23 10:51 AM
David wrote:I've just been testing in 14 through 16, David to make sure I wasn't getting confused... and for me I only get a value for "Ridge Length" or "Hips Length" (Valley length etc) for multiplane roofs. For single plane roofs these all schedule as zero.
But Graphisoft has addressed the Ridge vs. Peak issue with Single-Plane Roofs: A "Ridge" is calculated at 1/2 the length, a "Peak" is the full length.
2013-02-24 05:57 AM
Karl wrote:Karl:
2013-02-24 05:03 PM
David wrote:Yes... the automation. But, man, thanks for pointing out the pet palette 'Edge Type' option! Wow. That helps with a lot of other issues, even with multi-plane roofs! As often as I've used that palette for angle and material, I never noticed the Edge Type much less appreciated what it does for scheduling. Super. Thanks!Karl wrote:I think the difference is the automation of quantities. The Single-plane Roofs will deliver these quantities, but the roof edges need to be assigned via the Custom Settings Settings on the Pet Palette.
2013-02-25 11:03 AM
Karl wrote:This feature has been added to ArchiCAD in version 15 with the introduction of the new Roof method. So it is a rather recent addition.
