I have an object that I need to put opening lines on...however I have no idea what the best way to do this is. (The height and width changes) What is the best way of doing this?
Use the LIN_ x1, y1, z1, x2, y2, z2 command, which draws a line in 3D. If the opening line needs to be dashed, then you will need to code a loop that draws a series of LIN_s with intervening gaps.
David
David Maudlin / Architect www.davidmaudlin.com Digital Architecture AC27 USA • iMac 27" 4.0GHz Quad-core i7 OSX11 | 24 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
