2012-08-0904:44 PM - last edited on 2023-05-2412:35 PM by Rubia Torres
Hi All,
First of all, i'm using the dutch archicad 15 library.
When i use the Oval Window, there is a problem with the window-object when i use a reveal. When i don't use a reveal then the window is drawn perfectly.
On the picture below, you can see that the distance between the masonry and the window isn't the same for left-right en down-up. The reveal is the same (you even can't put in different values).
