Override cut line pen of complex profile?
karinamdp
Hi, at the Floor Plan and Section panel, of Beams and Columns, when using complex profiles can only override cut fills pens, but not cutting lines pen. is there a way of make this possible?
I will be very grateful if someone can help me
I am using Archicad 18 on Windows
AC25 INT
AC 26 INT & POR 4019
Windows 11
1 REPLY 1
As far as I know this is not possible to do in ARCHICAD 18.
However, in ARCHICAD 20 there is a new feature called Graphic Overrides, which can define multiple sophisticated override rules, where you specify criteria and an override style and elements meeting the criteria will be applied the override style.
This is a playlist that details the capabilities of this new feature:
https://www.youtube.com/playlist?list=PLnXY6vLUwlWXVIEZ4AFc-HeQtV7tdHs0O
