Design forum
PARAM-O Crash after change amount to 0
Vojtech Slavik
I started with Param-O and when I downloaded exempel from Archicad Website with Table.
I started little bit play with code and when I did mistake obviously and click to the 0 = with Deck Width.
Whole Archicad CRASHed.
I understand thats fail from me but how can I learn with it.  When it crash it with wrong number 😕 shouldn't be good get some popup with error message  ?
I'm using Archicad 26 and example was made in Archicad 24
AC 7 - 25 SWE
iMac (Retina 5K, 27-inch, 2017),
4,2 GHz Intel Core i7, 16 GB 2400 MHz DDR4
gavinNZz
Given Param-0 is so under developed its no surprise that bugs like this exist. I personally would spend my time learning GDL scripting because Param-0 is going nowhere fast. How can they expect us to build parametric objects but limit us to 3 exposed parameters! Ridiculous! Have a look at Vectorworks Marrionette to see what Param-O could be if they actually valued it. - https://www.youtube.com/watch?v=8V6l7zqUG7E
Marc H
Hi Vojtech,
I have experienced this with many apps over the years (i.e., bringing in other work product to edit).  As a general rule, therefore, I suggest starting with a blank node screen and building your object from a fresh start.  Not only do you avoid whatever compatibility or code issues there are/were with the original version, you also learn the logic of each step as you build. If its any comfort, I created about a dozen objects in PARAMO last year and they have been just fine in both development and object instances in design files.  One thing I would wish for is a lot more documentation and examples to ease the learning curve for us as architects.  The other is the 3D viewing window could be a bit more fluid.
“The best thing about the future is that it comes one day at a time.” - Abraham Lincoln
AC26 USA on 16” 2019 MBP (2.4GHz i9 8-Core, 32GB DDR4, AMD Radeon Pro 5500M 8G GDDR5, 500GB SSD, T3s, Trackpad use) running Ventura OS + extended w/ (2) 32" ASUS ProArt PAU32C (4K) Monitors
Didn't find the answer? Start a new discussion
