SOLVED!
Parallel Chords 1 Archicad 21
Hello, I am trying to edit an object from the linked library in archicad. I found a way to adjust it by every 4' starting at 8' but I would like a custom length to suit my project is there a way to adjust it to a custom length without it snapping to the 4' increments when I stretch it? I would like to have it 3/4" shy of 12'
1 ACCEPTED SOLUTION
Solution
David Maudlin
PBI Rookie:
The interface on my computer is a bit different than yours, but try this: at the top of the Steel Joist Settings panel is the parameter "Type of Steel Joist". Change this from "K" to "Custom", then you should be able to set the length to any value.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC27 USA • iMac 27" 4.0GHz Quad-core i7 OSX11 | 24 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
1 REPLY 1
Solution
David Maudlin
PBI Rookie:
David
Learn and get certified!
