2004-12-08 07:46 PM
2004-12-12 01:39 AM
Dan wrote:There are a number of inconsistencies / bugs (depends on your view what you want to call them!) in I.S. numeric formatting. The I.S. does use all of the available internal precision AFAIK. The problem is the display of the result.
If I place the value for the calculation into a "Real Number - PVOL" parameter the precision is "rounded" to 2 decimal places - not enough precision!
2004-12-12 11:33 PM
Karl wrote:Karl,
Try changing the number of decimals to display under Calc Units Prefs and see what you get. (Of course, you are limited to 4 digits there.)
2004-12-13 12:08 AM
2004-12-13 12:47 AM
Karl wrote:Karl,
...The number of digits displayed for real numbers in object settings is determined (apparently) by changing the setting shown in the screenshot below (Angle & Text Size Decimals in Dialog Boxes) ... even though the text prompt doesn't suggest that it would also change the digits for real number display...
2004-12-13 12:19 PM
...my "XY Coordinate Issue"...It's a bug, a discussed here. I haven't tried the tip in the last reply.
2004-12-13 05:50 PM
James wrote:James,...my "XY Coordinate Issue"...It's a bug, a discussed here. I haven't tried the tip in the last reply.
