Design forum
Partition area in plan
Carlos Schwarz
we are trying to list on a schedule the area that partitions occupy in plan but including the area where we have a door and taking into account wall intersections. Any suggestions?
We can't find the right parameter in AC24 or AC25, the closest would be to use "Area (general)" but that excludes the door's area.
We have tried creating our own property and multiplying "end thickness of wall" x "length of reference wall" but it  doesn't take into consideration the wall intersections (it double counts the area in the intersection).
We just found that in AC18 there was a parameter called "Area of wall" that is close to what we need but it seems to be gone? (even if in the description it says that "Wall intersections have no effect on the area value": https://help.graphisoft.com/AC/18/INT/AC18Help/03_2_Views_Virtual_Building/03_2_Views_Virtual_Buildi...)
We'll appreciate any suggestions. Thanks!
Carlos Schwarz Rodriguez, Architect
Lyall Bills & Young Architects, London
Archicad 24 6004 UKI Full on macOS Big Sur v11.6
iMac 27-inch 2020, i5 3.1Ghz i5, 32 GB 2667 Mhz DDR4, AMD Radeon Pro 5300 4 GB
12 REPLIES 12
Vinicius Guedes
Hello, @Carlos Schwarz
Could you illustrate your question with some prints and what's your objective, please?
Hi Vinicius,
Sure, I tried to be as descriptive as possible but I guess the image helps. See attached below:
On the left you have the modelled partitions and on the right I have measured with red hatches what we are trying to list: the "partition plan area" (a projection of the area occupied but the walls).
On the schedule at the bottom you can see the results for the property "area" and for our custom property as described in my first message.
Vinicius Guedes
Thanks, @Carlos Schwarz, I got your point 😉
I found the correct results using the "Area" parameter in the schedule settings, as you can see in the images.
To double-check it, I created another fill schedule.
Could your share your schedule setting, so we can compare it?Screen Shot 2021-09-21 at 12.32.18.pngScreen Shot 2021-09-21 at 12.32.34.pngScreen Shot 2021-09-21 at 12.32.45.pngScreen Shot 2021-09-21 at 12.32.52.pngScreen Shot 2021-09-21 at 12.33.00.png
I am not sure how you got the same areas, it seems that your wall area calculation is not considering the wall intersection? If they have the same lenght they shouldn't be both 0,20?) I think is just a coincidence they are matching, in the hatches the walls that are crossing have a reduction of 0,04 and on the walls the wall with the door has a reduction of 0,04). Can you double check with a smaller door please?
See below my screenshots. I can send you my pln as well, it's just a quick test file.
See my screenshots
Vinicius Guedes
@Carlos Schwarz I double-checked, and that's what I found:
I made 5 walls, 5 x 0,20 m each, then I've 5 m2 in total.
I intersected 2 walls, and it was reduced 0,4 m2, that was correct.
3 different doors were placed and the result was still the same, what seems to fit your expectation, right?
You can share the .pla file here, via WeTransfer link, so I can check it out.Screen Shot 2021-09-21 at 14.15.17.pngScreen Shot 2021-09-21 at 14.15.23.pngScreen Shot 2021-09-21 at 14.16.44.pngScreen Shot 2021-09-21 at 14.16.50.pngScreen Shot 2021-09-21 at 14.17.30.pngScreen Shot 2021-09-21 at 14.17.33.pngScreen Shot 2021-09-21 at 14.18.49.pngScreen Shot 2021-09-21 at 14.18.52.png
You guys may be using different Archicad versions (Ac24 vs AC25).
If I recall correctly, Ac25 includes some new ways of calculating area and volume quantities in schedules. Could that be the difference?:
https://helpcenter.graphisoft.com/user-guide-chapter/86698/
Laszlo Nagy, Lead Moderator, Community Admin
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, NVidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
Carlos Schwarz
Thanks both,
I think you may be right Laszlo as I was using AC24, but I have been playing a bit with those settings in AC25 and I didn't manage to get it right yet.
@Vinicius Guedes Yes, what you are showing is what I would like to achieve. Are you using AC25? can you share the calculations settings?
Here is my file if you have a moment to check it: https://we.tl/t-1hcD9qtHGK
Thanks!
Carlos Schwarz
Hi all,
I still can't find the way to make the "area" behave like @Vinicius Guedes did, can anyone help? Here is a short video showing how the area of the doors is substracted (we wish it was not) and showing my Archicad version and the calculation settings:
https://we.tl/t-bnARxP0SCQ
Thanks!
Vinicius Guedes
Hello, @Carlos Schwarz ,
After several attempts, I found why the results are different, and I'm checking a way to work around it
Vinicius Guedes
@Carlos Schwarz, I found that:
By default, my doors are modeled with the sill 100 mm to the home store, and yours are 0 mm.
So, my doors were not being subtracted from the wall's area.
As a workaround, you can model your walls with some distance in the button offset.
Hope this workaround can help you 😊
Screen Shot 2021-09-23 at 09.47.25.pngScreen Shot 2021-09-23 at 09.47.48.pngScreen Shot 2021-09-23 at 09.52.41.png
Carlos Schwarz
Hi @Vinicius Guedes ,
thanks for that, yes, it helps a bit. I wouldn't offset the wall by much as it would mean larger quantities for the walls, but as a "dirty" workaround I can use a sill of just 1mm and that is giving me the right area. It's not perfect though as it creates a problem with the floor's surface under the door.
Thanks for your help anyway
I will add a request for a new parameter to be added in the future (or brought back as it was there in AC18).
@Laszlo Nagy  How can I add a new feature request? I had seen it in the old forum but can't find it here. Thanks
Head to the Wishes Forum and start a new thread there:
https://community.graphisoft.com/t5/Wishes-forum/bd-p/ideas
People can LIKE your wish. Currently, this is the way people express their support for a wish.
Didn't find the answer? Start a new discussion
Labels
