Parts of the 3D model and the plan has disappeared
Parts of my 3D and 2D have disappeared, or are isolated from view in some way that I haven't actioned. I have not deleted the elements in question.
How can I see the entire modell again? I have tried clicking on "show all in 3D " und "View" but nothing has changed.
It is very frustrating
Many thanks!
did you try zoom to extend, select all... that sort of thing? I the 3D view, if you select all, and then zoom to selection, do you see any objects? Have you checked to make sure all cutting planes are off? We might need a screen shot to help you out.
Anything to do with Renovation Filters?
You may have one active that is hiding all of the 'new' elements for example.
Or the other obvious question - do you have all layers turned on?
runxel
Legend
Cut also be an accidentally activated 3D-cutplane (with those set to 'not show').
Lucas Becker | AC 27 on Mac | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text |
«Furthermore, I consider that Carth... yearly releases must be destroyed»
