Pens Set
Eman
If I create a 'pens set' and then I save it, then when I open an older project that 'pens set' doesn't appear in the pens & Colors of that project.
Eman / Draftsman
Works at an Architects Company using ArchiCad 21
Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz 3.19 GHz, 8.00 GB, 64-bit operating system, x64-based processor
David Maudlin
Eman:
Pens Sets are an attribute that are part of a project file (PLN), like Surfaces. They can be imported from another project file using the Attribute Manager.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David Maudlin
Eman:
David
Eman
Hi David, Yes I imported it. Thanks very much!
Eman / Draftsman
