Design forum
Photorendering setting toolbar
Tom Krowka
Hey....for some reason photorendering settings dialogue box won't show up. Was working fine until yesterday. For some reason.....no show. Have minimized AC, thinking it might be behind the window....no go. Have rebooted thinking it's the video card memory Did not help. Every thing else seems to be fine. Any ideas?
Tom Krowka Architect
Windows 10, AC Version 25
Thomas@wkarchwk.com
www.walshkrowka.com
1 ACCEPTED SOLUTION
Solution
Nguyen Minh
Graphisoft Moderator
Hi Tom,
Thank you for the question!
I'm wondering when you open the palette, does it freeze Archicad, or it just does not appear anywhere? If the later is the case, I'm afraid that the dialog has been pushed off the screen by accident. Are you having multiple display setup?
I would like to suggest trying the following things:
(your account on Windows needs to be Administrator type, and ARCHICAD need to be closed before taking these steps)
- Go to C:\Users\[your account name]\AppData\Roaming\GRAPHISOFT\ARCHICAD XXXX\ then delete the file ARCHICAD Basic.prf
If it doesn't work, then:
- Open Registry Editor by right-clicking on Start button, select Run. Type regedit then press OK.
- Go to the following directory: HKEY_CURRENT_USER\Software\GRAPHISOFT\ARCHICAD\ARCHICAD XXXX\Dialog Manager Custom Data, then delete the file RenderingSettingsPaletteRect
(XXXX is the version of ARCHICAD on your computer)
Sometimes a computer restart may help with the issue!
Let me know how it goes for you!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
7 REPLIES 7
Braza
Did you try Menu > Windows > Palettes > Photo Rendering Settings?
Paulo Henrique Santos, Architect
AC24_INT#3008 / I7 / 16Gb / 512Mb SSD / Windows 10
Tom Krowka
Yes. When I select it I get the hourglass symbol bot no dialogue box.
Thomas@wkarchwk.com
www.walshkrowka.com
Braza
Strange... Perhaps updating your graphics card drivers...
Solution
Nguyen Minh
Hi Tom,
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
Tom Krowka
Thanks for the prompt reply. Dialogue box simply doesn't appear. Am using two displays, but occurs when using only laptop. Rebooting computer did work once, then had problem again. Seems to work fine on multiple display.
Will keep your solutions on hand in case it happens again.
Thanks Tom
Thomas@wkarchwk.com
www.walshkrowka.com
runxel
Mentor
There is actually another way: editing the workspace xml.
AC 24 [ger] | Win 10 | Developer of the GDL plugin for Sublime Text |
«Furthermore, I consider that Carth... yearly releases must be destroyed»
Tom Krowka
Go to work environment solution is the way to go. Thanks for the tip
Thomas@wkarchwk.com
www.walshkrowka.com
Didn't find the answer? Start a new discussion
Labels
