Poligonal Walls -Window & Doors
It's either staring me in the face, or it's impossible.
I'm currently working on a 17thC stone building with walls that vary in thickness from 30 to 60 cm (ie forming a wedge in plan). As it is a listed building, the walls must be perfect. I draw the tapered wall, but cannot insert windows or openings.
1) Is it possible?
2) Is there a work around?
3) If the answers to above are negative, then why have this wall option if openings cannot be inserted?
I could not find any specific reference to this via the search engine, so if it has already been dealt with, then I apologise profusely. If that is the case, please point me in the right direction without being too patronizing.
Thank you all in advance,
shaun
10 REPLIES 10
Scott Davis
Adalbert wrote:
I decided to wait until Revit has its interactive energy analysys solution.
The Green Building Studio energy analysis doesn't work for you?
Scott Davis
Autodesk, Inc.
On March 5, 2007 I joined Autodesk, Inc. as a Technical Specialist. Respectfully, I will no longer be actively participating in the Archicad-Talk fourms. Thank you for always allowing me to be a part of your community.
