2012-04-10 01:29 AM
2020-06-02 03:23 AM
Richard wrote:
Too bad, as it would likely take someone like you about 20 minutes to fix, if that.
Win10 | R5 2600 | 16GB | GTX1660 |
2020-06-02 10:17 AM
Richard wrote:Perhaps I'm misunderstanding the problem, but the labelling options are quite extensive and should easily solve that - take a look under the label panel in the object settings:
Sadly, the one very simple thing it doesn't do is let you change the text for switches. (Maybe receptacles, too.) For example, we need the ability to change the text label "D" (or whatever it is) in a switch to VS (for Vacancy Sensor) or a "3" or "4" (for 3-way or 4-way switch) I sent a support ticket on this and was simply told "it's not possible." I downgraded my subscription as a result, and CI lost hundreds of dollars annually. Too bad, as it would likely take someone like you about 20 minutes to fix, if that.
2020-06-02 03:39 PM
2020-06-02 03:58 PM
Richard wrote:The localised objects all use the same underlying scripts for the UI - they just vary in how they render the 2D/3D representation to suit each country. Therefore the labelling is exactly the same for all countries (a snapshot of the US version is attached).
Ralph,
That is exactly the issue and how I would have expected it to work. However, this did not work with the U.S. switches (the label was apparently hard-coded), and tech support merely confirmed that there was no way to get it to work. I didn't even get a "oh, this is a bug, we'll get it fixed." You should be able to find the issue & response in your past support logs. All of my closed support tickets have evaporated off of the CI website, so I can't help with this.
2022-04-03 10:54 AM
The German Subscription Service ArchicaRd offers smart gdl sockets and light switches to add into the library.
2022-12-24 06:55 PM
So we are basically almost 2023 and still can't find a basic outlet/socket in the standard library for AC26?
2023-01-10 07:32 AM
Sadly, I have to agree... These are very basic objects to include: power sockets (1 gang / 2 gang / 3 gang), IT sockets, light switch (single, double, triple)... So basically the electrical drawings can only be done in 2D.
