Prism with a smaller base than top...
JGoode
Hello,
I want to make a prism that has curved corners and also a smaller base than top (like a cone).
What is the best way to achieve this?
Thanks
ArchiCAD 23
Windows 10
4 REPLIES 4
Probably RULED or SWEEP.
But maybe TUBEA.
I have used RULED to make baths and basins where the size changes with height.
Lingwisyer
Guru
But how do you make just the corners rounded?
For the SWEEP you can do something like this.
SWEEP 13, 2, 0, 2, 1*1 + 2*1 + 4*1 + 16*1 + 32*1 + 64*1,
              -0.025,        -0.05,     1,
               0.025,        -0.05,     1,
               0.025,       -0.025,    900,
                   0,           90,   4000,
                0.05,        0.025,     1,
               0.025,        0.025,    900,
                   0,           90,   4000,
              -0.025,         0.05,     1,
              -0.025,        0.025,    900,
                   0,           90,   4000,
               -0.05,       -0.025,     1,
              -0.025,       -0.025,    900,
                   0,           90,   4000,
				0, 0, 0,
				0, 0, 0.2
With the RULED I think you have to specify many points on the curve (i.e. many straight lines).
I think this is because the nodes of the polygon are listed twice - the first has a status code for visibility and the second has the height - so the mask for curves doesn't work.
I use a gosub routine like this to create the many nodes of a corner.
start_angle = 180
end_angle = 270
x_add = -x_val-x_squ_add
y_add = -y_val-y_squ_add
gosub 100
100:
FOR angle = start_angle to end_angle step 10
PUT x_add+(rad*COS(angle)), y_add+(rad*SIN(angle)), z_status
next angle
RETURN
I have never really used the TUBEA so can't comment on that one.
Lingwisyer
Guru
Is it the edges or the corners that need to be curved?
Learn and get certified!
