Problem Importing From Rhino
I am using the archicad export plugin with rhino geometry. The first problem is that it never comes into archicad at the correct scale. We have tried switching the units to every configuration we can think of and still nothing. The other problem is that once it's in archicad, we can't scale the object. Whenever I use the resize command, it just moves, but doesn't actually scale. How do we fix this? It's causing serious delays in our workflow
1 REPLY 1
Katalin Borszeki
Dsquad96! PLease send us files, because without a relevant file we are unable to reproduce this issue! Thanks! k
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
http://helpcenter.graphisoft.com - the ArchiCAD knowledge base
Learn and get certified!
