Problem with projection 2d in composite wall
Mario Sacco
when I have a lower interior wall represented as projected in floor plan, the intersection is incorrect.
MacBook M1 Max 64GB- OS X 12.2.1 - Archicad 27
https://www.archiradar.it/en/
6 REPLIES 6
Link
Can you change the layer intersection priority number so that it doesn't try to join? If that solves it just remember that you'll need to update all of your layer combos with this new setting.
Link.
Marton Kiss
What are the priorities set for each Building Materials that are in use? I tried to re-create a similar situation, where the wall intersects with a core of the wall, but when I set it to end under the cut plane, the representation showed up correctly.
Marton
Marton Kiss
VP, Product Success
GRAPHISOFT
Hi Gents,
I have the same problem.
Here is the 3D view of an example started from the US commercial template file. Its a corner with a partial height wall intersecting it.
The plan view with floor plan cut plane at 3'
The plan view with the floor plan cut plane at 7'
The materials do not intersect correctly like it does in 3D
Also I cannot get the 2D line to disappear.
