If you have a support agreement I would lodge a support ticket and ask that someone contact you to discuss it or you could try calling 1300 USE BIM (873 246) (Australia only).
The LCF file can be extracted and then you can edit the objects.
In the PARAMETER script you will find a command ...
HIDEPARAMETER ALL "A", "B", "ZZYZX"
Comment that out and you will have the ALL PARAMETERS back.
There is no need to convert back to LCF format.
The only reason for an LCF is it is easier to manage 1 file and I believe it loads a little faster - but there wouldn't be much in it.
LCF is a pain if you are editing files.
