Project Preferences: How to Save, Export, Import?
4hotshoes
Todd Oeftger
AC27 Mac MacBook Pro 15", 2019, 2.3 GHz i9, 32GB, Radeon Pro 560X 4GB, 500GB SSD, 32" Samsung Display (2560x1440)
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Dear All,
Thank you for sharing your ideas and opinions regarding this request!
I'm glad to say that we took notice and we have added this Wish into our Wish database.
(For future reference, you can refer to it as IDEA-4362)
I hope we see this get implemented in the future.
Have a great day!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
8 REPLIES 8
It may help you to know that a different Dimension Preferences can be saved with each View in View Settings.   Many people have their Templates set up so that of  the Views already have the appropriate dimension preferences needed.   2021-10-07_14-03-56.jpg
DGSketcher
Legend
One for the wish list when it resurfaces...
I do know that. But I want to transfer settings from a template to a file that was setup wrong. I have been able to export and import many other settings. I was hoping that I was missing something on how to do it. There are many little tedious details set in the Dimensions Preferences.
Todd Oeftger
As far as I know it is not possible.
Even merging files do not bring the project preferences across.
Every time you configure/change a Dimensions Standard you can "Store As" and it will be there as an option when you open a new project with  Latest Project Settings.  Personally, I can't think of the last time I needed to load Dimension Standards in to a project that didn't have the ones I need.  They always seem to be available or it is just a couple of key strokes to modify for some special use the Store As function.  Just out of curiosity, why are you needing to load the dimension standards into a file that doesn't already have them?
I suspect that you don't use the Project Preferences for Dimensions the same way I do. I use them to check accuracy of added dims by changing rounding from the nearest 1" to 1/4" to 1/64". I will change the dims to display meters or mm, inches, feet and inches or just feet depending upon the project. As I work as a consultant, I receive many different configured project files that are not set up to make work more efficient. The ability to export and import Project Preference settings would greatly simplify my life. I don't have the luxury of working with my own preset template most of the time. This option should be a no brainer for Graphisoft to include.
People can talk about world peace and to solve the worlds problems all they want, but the simplest solution is to just use your blinker!
Todd Oeftger
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Dear All,
Have a great day!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
I use dimension just as you mentioned sometimes too.   Yes, I agree,  it would be very useful to Import-Export all of the Project Preferences.
