Protect your objects.
Cosminn
Hello everyone.
I am trying to create an object that should be used for Projects from our Bim server. If a user is trying to use it on Projects who are not loaded on our Bim Server, then should not work, if make sense.
What you suggest for this?
1. I was thinking to protect that object using the Bim Server license, based on the fact that users are using a borrowed license. [not sure if that will work].
2. I was thinking to protect that object using the Path of the file. wich is on my Bim Server on a certain drive.
Any suggestion will be greatly appreciated!
Thank you
Sincerely,
Daniel
0 REPLIES 0
