A Layer cannot be purged if there are any elements on it. Sometimes (by mistake), elements can be placed on a layer that will later require purging. This can occur in any of the possible views (plan, section or detail). To hunt down the offending element can be time consuming (make the layer to be purged the only visible layer, then review each plan, section or detail window fully zoomed out, delete or move elements to a new layer, make sure no tool is linked to that layer).
Finally the question: Is there a quicker method for locating offending misplaced elements to expedite layer purging? For instance, “Show or reveal all windows and elements on a particular layer.” Thank you.
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
