2018-03-1605:45 PM - last edited on 2023-05-2302:13 PM by Rubia Torres
When I connect a ramp to a slab, the plane of the ramp is not aligned with the slab in 3D. (see the screenshot). It looks like that there is another slope perpendicular to the roof pitch. It's maybe because the two elements are not connected by a 90 degree angle but still I expect to see the two nodes at the same height.
Check the angle of the Roof's Pivot Line (turned on via On-Screen View Options). Since the Roof and Slabs don't intersect in plan at a 90˚ angle, I think the Roof Pivot Line will need to be parallel to the intersection angle.
David Maudlin / Architect www.davidmaudlin.com Digital Architecture AC27 USA • iMac 27" 4.0GHz Quad-core i7 OSX11 | 24 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
