Design forum
Railing Post Ends
ksjhawk
Is there a way to gat what I describe in the attached PDF? While the railing tool has a lot of positives, we do a fair number of custom barstock railings and we get very specific about where the posts go. I have tried separating the segments, but my biggest problem is the ends of a segment are always treated the same. In some cases, I'd like to have one post at a node (transitioning from landing to stair run) and in other cases would like the end to place two posts either side of a node (as in the corner of the landing).
Is there an easier way to do this or should I go back to columns for rail posts so I can put them right where I want them? Also, is there a way to adjust the inner posts (to line up with treads for instance)?
Thanks...
4 REPLIES 4
Bruce
I'm new to figuring out this railing stuff too, so apologies if I tell you stuff you've already tried. However, play with the settings in the following three areas to see if it achieves what you want:
1. Segment > Railings on associated stairs
Bruce Walker
http://www.brucepwalker.com
https://www.mindmeister.com/65450406
-- since v8.1 --
AC22 6025 INT Full | macOS Mojave 10 | 3.2 GHz Intel Xeon W | 32 Gb RAM | Radeon Pro Vega 56 8 Gb
Bruce
2. Inner Posts > Single or duplicate inner posts
Bruce Walker
-- since v8.1 --
Bruce
3a. Nodes > Number of posts and offset
3b. Nodes > Pattern continuity
Bruce Walker
-- since v8.1 --
ksjhawk,
In Railing Editing Mode, select any Post of the Railing, then right-click and use the "Convert Pattern to Segment Length" option. This way each Post will be treated individually and you can select one Post, and set it to a single post, then select another Post and set it to Double Post.
Laszlo Nagy, Lead Moderator, Community Admin
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, NVidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
Didn't find the answer? Start a new discussion
