Railing not showing on any plans but will show in section
4hotshoes
I have found a bug in the Railing Tool, where a railing that I have drawn will NOT show in plan, but is selectable in plan, BUT will show in 3D. I have checked the MVO and Floor Plan Display settings. I have compared those settings with a railing that does show on plan and I have changed all of the settings of the invisible railing to match the visible railing and it still will not show.
Todd Oeftger
AC27 Mac MacBook Pro 15", 2019, 2.3 GHz i9, 32GB, Radeon Pro 560X 4GB, 500GB SSD, 32" Samsung Display (2560x1440)
1 REPLY 1
Hello 4hotshoes,
There is a solution or a reason for each "mistake".
Before conclude to a "bug" we have to check all the options.
If there is a classical reason I will be able to find it easily.
Can you share your file please ?
Did you specify which Archicad you use ?
Have a great end of 2019 !
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2017 - 16Go RAM
