Design forum
Railing return off center in plan, but aligned in 3D
LM19
In plan, a 1 1/2" square railing shows the 90 degree return 1" off center from the guard rail post it is supposed to connect to. In 3D however, the return is in the exact right position. The railing is also showing up in red on the plan, so I'm guessing something is wrong with the settings. Any guesses? I'm in AC24
I'm modeling an existing railing, the main object being rendering an image.
We are also using this model for construction docs, so the 2D plan view is also important
Can you show screenshots of both the 2D and 3D of the Railing, so we can see the misalignment between the two?
Laszlo Nagy, Lead Moderator, Community Admin
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, NVidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
runxel
Mentor
I recall a recent thread with nearly the same content. Minh stated that this behavior (right in 3D, wrong in plan) would be a bug that will be fixed (with no ETA, tho).
AC 24 [ger] | Win 10 | Developer of the GDL plugin for Sublime Text |
LM19
Here are the screen shots. Sorry for the delay. I haven't been back on this project for a bit
Didn't find the answer? Start a new discussion
Labels
