2022-11-27 07:59 PM
Does anyone know how I can connect this railings termination?
Solved! Go to Solution.
2022-11-27 08:29 PM - edited 2022-11-27 08:37 PM
Has been an issue since the Railing tool was introduced. You cannot do a closed path. The closest you can get it to terminate on an edge, removed the unneeded post, and set the rails and toprail to have zero end offset.
Ling.
Win10 | R5 2600 | 16GB | GTX1660 |
2022-11-27 10:25 PM - edited 2022-11-27 10:26 PM
terminate at the middle of the side, not at the corner, as described above. that is the solution to the bug.
2022-11-28 04:27 PM
I'm not sure I understood the process exactly. I tried to do it but it was looking like a big kludge. Changing the offset value to zero didn't seem to have any effect. I got something close just by dragging elements in the edit window.
Perhaps a video will make this process clearer. If it's not asking too much. Thanks in advance
2022-11-28 04:58 PM
The continuing corners will trim as you expect.
The start and ends will not trim when forming a corner and there is no way to mitre the ends unless you perform you own Solid Element Operation.
By starting in the middle of a straight edge, the ends will abut each other perfectly, but you may end up with a joining line.
2022-11-28 07:07 PM
Base railing;
Zero ALL of the end offsets;
Zeroed offsets;
Given posts and balusters, in EDIT MODE I have deleted one END POST and changed the size of the other to match the balusters;
Result;
