You can re-order your View Map however you like (except in the case of cloned folders...which maintain their project map order...a reason I don't use clones). But, you cannot re-order the Project Map.
Once you have a decent template, you would almost never use the Project Map anyway?
One of the forum moderators
AC 27 USA and earlier • macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
