Reflected Ceiling Plans (RCP)
ares997
The 3D Document RCP tool is great but I can't get my teams around it because it doesn't show the lighting symbols in a manor that is conducive to a RCP. It would be awesome if it could just create the 3D document and get the symbols to show as they should in a typical RCP, with the correct representation for the symbols.
So how do you do your RCP's with AC17?
Do you use a hybrid approach?
Do you use the RCP/3D Document tool for this?
Archicad 25 (5005), Windows 11, AMD RYZEN 7 3900 (64 GB RAM)
1 REPLY 1
ares997
How are you using it? How can it be used more effectively?
