Design forum
Removing the plus symbol from Level Dimension
D_Amsell
Could anyone tell me how to remove the plus symbol in my level dimension, shown attached? This is a level dimension with <toL1value> autotext.
I can't for the life of me figure out what is controlling this setting.
I have a different .pln file where it's working correctly (dialog also attached), but I haven't been able to identify where the setting is to spot the difference.
Thanks!
1 ACCEPTED SOLUTION
Solution
James B
You've currently selected just the Level Dimension Text, if you select the Level Dimension itself, the settings dialogue has 2 options to show/hide the +
Product Manager, Graphisoft
2 REPLIES 2
Solution
James B
D_Amsell
Can't believe I missed that! So obvious. Thanks so much!
Didn't find the answer? Start a new discussion
