Renovation filter problem
ehsanheydari
Hello everyone,
I am facing with a very strange problem which kind of become a big problem!
I am trying to  show a plan that shows comparison of demished element(yellow color), new costructed element (Red color) and existing element with original color and setting. to show you clearly my situation I  made a simple example of a window in wall. if you see the first screenshot 1 you can see that in plan view everything is fine and I can see the demolished window in the existing wall with right color. but when I go to elevation view, somehow very strangely the windows is diseapered and I am just seeing the existing wall with just opening of the windows and i dont see any windows(Screenshot2). However, If i change the wall to be in demilished phase again I can see the window (Screenshot 3).
I would be very thankful if someone knows how to solve this problem.
Good day,
Ehsan 
Ehsan Heydari / Civil Engineer
AC24 INT • Intel(R) Core(TM) i5-10400 CPU 2.90 GHz | 32 gb ram
13 REPLIES 13
Hi David,
Yes that could be also an option but it is very strange that there is no option for seeing both of them together.
by the way thank you so much and thank you also for the tip about signature
yes exactly,
how it is possible to do it please?
Hi bruno,
Yes but it didnt work
You need to set several things.
1. Graphic Overrides.  See image below for reference.
If you want your Grid lines to be in black lines you also need to add that in the combination but mainly your criteria would be set in this way.
(** take note that it will be transparent in your elevation so you need to take care of the elevation horizontal range)
2. Renovation Filter. See image below for reference.
Hope this helps you. 😎
In the end what is your Objective?
ArchiCAD 9 onwards
