Thanks Laura.
I read it, but sometimes it works, and sometimes it does not.
I wouldn't have posted a separate thread otherwise, with all the screenshots.
That's the only issue it might be?
I've experiemented, and just sometimes it works, and sometimes it does not.
Like it just worked, in the drawing above, but doing it for the last 5 minutes it didn't. Honestly I am connecting the nodes, and even with the wall reference nodes meeting and touching, on top of each other, and the wall clean up button "on"... just it only does this sometimes. I've changed the scale, zoomed way in to make sure they touch- all of which are more time consuming and slow methods. Is there some global setting I can change for when the modes get close they will snap and clean up the junction, like when they are within 1cm of each other???
If no one else knows something about this that might be helpful with deeper settings, or can point me in a new direction, I might try reinstalling= maybe something went AFK in my install or something, as this seems to be a personal issues rather than anyone else having a general issue with this function...
Thanks again- and thank you Laura. I'm trying it out...
