Design forum
Rhino 6 has stopped working
JGoode
My Rhino keep crashing whenever it tries to send to ArchiCAD 23. It isn't a complex script and the same script was working. Is there any way to fix this or does anyone else have any experience with the same issue?
I've attached an image of my script. As you can see it isn't very complex. It crashes with or without the button.
Any help would be great.
Thanks
EDIT: I've narrowed it down to if a zone has a hole cut for a column, it causes the error. Which is strange as it previously worked when I tried it. Is anyone able to help me get around this issue?
Thanks again
ArchiCAD 23
Windows 10
1 ACCEPTED SOLUTION
1 REPLY 1
Solution
JGoode
Problem solved by adding a curve in between polygon and geometry
ArchiCAD 23
Windows 10
Didn't find the answer? Start a new discussion
