Parametric design
About Rhino & Grasshopper and PARAM-O.
Rhino 7 Live connection
Are there any news regarding the AC live connection for Rhino7? It is quite troublesome that there is still no sign of the appropriate AC-GH connection....
6 REPLIES 6
Search for the threads that attested to the fact that it could be made to work - and how to do it.
Think Like a Spec Writer
AC4.55 through 27 / USA AC27-4060 USA
Rhino 8 Mac
MacOS 14.2.1
Hi Aaron,
do you mean this one?
https://archicad-talk.graphisoft.com/viewtopic.php?f=43&t=69618&p=322851&hilit=archicad+live+connect...
I couldn't find anything related to how to make it work for RH7. The "fix" for RH 7 WIP i already tried and it does not do the trick. If you have a particular post in mind, i would appreciate if you could point it out.
it's in this thread. https://archicad-talk.graphisoft.com/viewtopic.php?f=43&t=71301&hilit=Rhino+7
Rhino 8 Mac
MacOS 14.2.1
James B
We are working on adding Rhino 7 support for the Grasshopper-Archicad Live Connection, and expect to release an updated add-on later this year.
James Badcock
Graphisoft Senior Product Manager
Thank you for your feedbck, I just downloaded the latest release with Archicad 25, and was disheartened to see it still doesn't work, meaning I still have to keep Rhino 6 around just for the sake of connection... and keep sometimes working on Rhino 7 and going into Rhino 6 just to use the connection. I hope it will be operational soon.
Hi James, regarding the Rhino-Archicad connection, do you know if anyone is experiencing the same problems highlighted on the Rhino forum? Sorry I don't know who else can help, being a shared plugin. Thanks https://discourse.mcneel.com/t/grasshopper-Archicad-live-connection-anchor-point/130858/7
Learn and get certified!
