2015-09-15 07:34 PM - last edited on 2023-05-11 11:12 AM by Noemi Balogh
2015-10-01 03:28 PM
2015-10-08 12:16 AM
Olivier wrote:How is it smart? As near as I can tell, the ArchiCAD add-on will convert a .3dm into a .gsm, and in doing so you can control the poly count to make it as smooth as you can. However, unless the imported object has smoother curves and surfaces than we can make in ArchiCAD with out it, what is the advantage? Rhino already generates a number of 3d file formats that we an import into ArchiCAD. .3ds, .obj, .skp, etc...
Just wanted to congratulate GS for a supersmart move!!!
2015-10-08 12:48 AM
2015-10-08 02:34 PM
Steve wrote:If you have seen the webinar you know that ARCHICAD will now have a live bidirectional connection to the best freeform modeling application and visual scripting application, so they do not have to develop their own solution from scratch. That I think is a smart move. ARCHICAD users will be able to take advantage of all the development effort put into Rhino and Grasshopper to improve their BIM workflow. Architects currently using Rhino may decide to take up ARCHICAD to improve their BIM workflow.
How is it smart?
2015-10-09 02:00 AM
2015-10-09 02:54 AM
2015-10-09 04:00 AM
2015-10-09 08:21 AM
2016-01-07 01:08 PM
