Options menu > Project Preferences > Legacy...
If you are using single roof planes and getting the true 3D top view then you will see the top and bottom surface edges of the roof if the bottom surface is larger than the top (i.e. edge not vertical).
Multi-plane roofs you never will because all planes join together automatically.
