Design forum
Roof Wizard can't find library parts
I'm trying to use the Roof Wizard and it cannot find the library parts. I'm using AC8r3 the library is the latest available from the GS tech resource site. I use the pla version.
Anyone have any solutions/suggestions?
TIA
David Larrew
Works fine for me.
Are any other libraries loaded in the project besides the default .PLA?
Are any of your other "Extras" Add-Ons not finding the library?
David Larrew, AIA, GDLA, GSRC
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
David wrote:
Works fine for me.
Hi David
Thanks for the responce.
There are a few libraries loaded in the project I'm working on so based on your query, Yet again, I've tried a new and reset with the latest library (only that library) and then even one with the previous 8 library to no avail. The other Add-Ons appear to be working "fine" (or at least how their suposed to ) when I search through the library with the Object Tool the parts it claims to not be able to find (Rafter and Beam ) appear to be there.
The only other thing I can think is the Roof Wizard has been snooping through the calander and is aware of the impending deadline.
Thank You
David Larrew
Jeffrey,
One thing that you could try... re-installing just the "RoofMaker" Add-On.
You could also try blowing out your .PRF files from your "ArchiCAD" program folder. (Be aware that you will lose any customized hot-key assignments and other user default settings.)
AC 5.1-25 USA
Didn't find the answer? Start a new discussion
