2004-01-16 12:55 AM - last edited on 2023-05-23 03:44 PM by Rubia Torres
2004-01-16 04:16 AM
2004-01-16 06:56 AM
2004-01-16 07:30 AM
Dave wrote:Is the visibility of your roofs set to One storey above and below? If you do that, AND change the default that the objects are seen as dashed one storey above (something I have been asking for since I started using ArchiCAD), it should work - BUT, only for one storey above and below ... or if you need it on all stories, that is also possible as you know.
The Construction Elements Preference only works on objects that you can select to ignore the objects standard linetype--hence my question. Is everyone using a workaround like I am?
2004-01-16 08:11 PM
2004-01-17 12:03 AM
2004-01-17 12:47 AM
Matthew wrote:Right. Unfortunately, I often have exposed beams and rafter tails (which I don't care to dash in overhead.) As always, thanks for the help.
If you model the soffit (assuming such is part of your design) with a slab, you can set that to make the dashed outline you desire. The inside line of the slab is hidden by the exterior walls.
