Rotating hotspot with unwanted normal hotspot
JGoode
I have a 2D hotspot that I am using to rotate my object however there is a black base hotspot that stays in place when the rotating hotspot is moved. Is there any way to remove this? I've looked at the gdl ref guide and changed the flags but it doesn't seem to work. Here it is:
 	! Center
 	hotspot2 0, 0, hsID, ang, 6     : hsID = hsID + 1
 	! Base
 	hotspot2 1.1, 0, hsID, ang, 4     : hsID = hsID + 1
 	! Moving
 	hotspot2 1.1 * COS(ang), 1.1 * SIN(ang), hsID, ang, 5    : hsID = hsID + 1
Thanks!
ArchiCAD 23
Windows 10
Lingwisyer
Guru
Adding the attribute 128 to your base hotspot does not work?
 hotspot2 1.1, 0, hsID, ang, 4 + 128     : hsID = hsID + 1
Ling.
4 REPLIES 4
Lingwisyer
Guru
Ling.
JGoode
No, the black hotspot remained in place.
ArchiCAD 23
Windows 10
It works fine for me just as Ling has shown.
JGoode
ah I found my error, turned out I had more than 1 hotspot and one of which didn't have the +128! all sorted now.
Thank you.
ArchiCAD 23
Windows 10
