Ruled shells
Frank Beister
Is there any way to make edges of RULEDSHELL generated objects make invisible? I have to eleminate the edges of starting and ending plane or the generating polylines. The normal RULED command has a separet mask parameter, which is missing in the RULEDSHELL command.
Can anyone share his experinces?
1 REPLY 1
Joachim Suehlo
The GDL manual does not say anything about mask parameters.
Changing the status values does not change the visibility of the edges.
Maybe you should try a cutting command with invisible edges as workaround.
Joachim Suehlo . AC12-27 . MAC OSX 13.5 . WIN11
GDL object creation: b-prisma.de
