Tom,
Yeah, I had the same script in my object.
The problem is:
- once the object is part of a module, the schedule doesn't show the correct handing.
It is because the schedule doesn't trigger running the parameter script, hence it always show the default value.
This is why I was hoping to get access to the actual tick box value in the module setting.
It seems I can't access the module source file name either, unless someone knows a secret there.
The only option I know works is to "run parameter script... Manually fit the whole project. That takes hours...
Any better idea?
ArchiCAD since 4.5
Windows 10
