Selection of Labels of Column, Door / Window independently
ratnabhirud
Does anybody know how to select Labels of Column, Door / Window independently in AC 17 ? ( except Find & Select option )
It is very easy to select the same in previous versions of Archicad using Quick Selection tool.
Regards,
Ratna
AMD Ryzen 5 3600 6-Core Processor 3.59 GHz
Ram - 16.0 GB
System - Windows 10 Ultimate, 64 bit
NVEDIA GForce 8400GS
Archicad 9..., 24
5 REPLIES 5
Why can't you select them the way you did in previous versions?
ratnabhirud
Thanks for responding this..
Basically when I move my cursor over any Label, it does not highlights as it happens in previous versions.
Instead of highlighting Label, a tiny blue dot is visible after too much zooming and then I can pick it, but it is not possible for every label to do faster work.
Regards,
ratna
Ram - 16.0 GB
Archicad 9..., 24
David Maudlin
ratna:
AC17 Quick Selection works here as in previous versions. Are you sure it is turned on (Arrow Tool > Info Box > magnet is depressed) or in the Help files Interaction > Selection > Selecting Elements > Quick Selection of Surface Areas.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
ratnabhirud
Hello David,
As per image attached, one is from AC ver14 & Another is AC ver17, in which one can clearly see the difference. Please note that in AC 14 image , magnetic cursor is not captured..
I am not
Thanks & Regards,
Ratna
Ram - 16.0 GB
Archicad 9..., 24
ratnabhirud
I just came to know that if Col / Beam/ Door / Win Label has any Marker head selected in it's Label settings , then AC shows Quick selection icon & if it is set to none then it does not show any selection Marker.
Is Quick selection icon does not appear for No Marker Head ?
Regards,
Ratna
Ram - 16.0 GB
Archicad 9..., 24
