Design forum
Show hidden lines of beams in section
Hello everyone,
Is it possible to show the hidden lines of a beam in a section?
I'm currently modeling an old home wich has wooden beams that are inserted into a brick construction wall. It would be nice to show these beams that are inside the wall in section with a dashed line.
So far I could only find settings and tutorials about the display of beams in floor plan, but not the section.
Thanks in advance for any advice!
4 REPLIES 4
I am afraid you will have to do that manually.
Archicad does not offer such a feature in Sections.
Laszlo Nagy, Lead Moderator, Community Admin
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, NVidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
Ok thanks for your reply!
runxel
Mentor
Laszlo is right, natively there is no function like this.
(You could make wish, I suppose this is something many of us could need in one or another kind of situation.)
However, Heimo Mooslechner did something similar for walls in an elevation back then with labels:
https://www.youtube.com/watch?v=qpkOegPqrxs
Maybe this works with beams, too.
AC 24 [ger] | Win 10 | Developer of the GDL plugin for Sublime Text |
«Furthermore, I consider that Carth... yearly releases must be destroyed»
Thanks for the link runxel, I will try that out!
Didn't find the answer? Start a new discussion
Labels
