The ceiling slab is not related to the roof, so yes you will have to manually cut the hole in the slab.
There are techniques to cut the hole in the slab but use the roof plane as your editing plane and project the hole onto the slab.
So effectively you are picking points on the roof (the extents of the sky-light) and you are cutting the hole in the slab - projecting vertically or perpendicular to the roof.
The Help Center arcticle may help.
https://helpcenter.graphisoft.com/user-guide/76363/
Scroll down to the sections for "Pick Plane Example" & "Projection onto Editing Plane".
I am sure there was a good movie explaining this when the feature first came out.
Maybe in the Archicad YouTube channel?
If I can find it I will post a link.
