Slab lines thickness...
Llian
Not sure why some of the slab cut lines are thicker when all settings are the same.
Any thoughts?
Lilian Seow
LEED AP | cSBA
Interior-Architecture and BIM Management
AC20 USA | 27- macOS 10.14.6| 4 GHz Intel Core i7| 32 GB RAM | Archicad-user since 1994!
2 REPLIES 2
Lingwisyer
Guru
Looks a lot like when you have Profiles turned on in Sketchup. Do that stay like that if you pan around so that these edges project towards you? I have never noticed AC doing this...
Ling.
Edit: Are you using the Vectorial Engine? If so, it appears to be defined by the Silhouette Contour 3D Style setting.
Yes, it is the 3D style settings.
Learn and get certified!
