Design forum
Sloped/ tilted morph, fitted railing
Anais1
I am trying to add a fitted railing to a morph that I am using as a roof/ terrace.
as you see in the picture the morh in question is the green line deviding the selected mesh i am attempting to make fit as a railing. I have tried to use complex profiles, beams and regular rails, non of which worked tue to the complexity of the morph. I am now attempting to devide the mesh using the morph, then delete the then residual bottom part, copy the top part and move the copied part up and cut the top part off at the correct angle.
I am am however curious about all types of solutions to this that one can come up with.
All advice is welcome, thank you in advance:)
If you mean why the railing is not showing in plan, I can think of 2 reasons that it might be.
One is the Model View options.
The other is the Floor Plan Display in the railing settings.
Versions 6.5 to 25
4 REPLIES 4
You might not be able to magic wand a railing to a morph, like you can a slab or roof.
But you can place the railing by picking the morph nodes in 3D - the rail will follow the heights of the morph nodes.
It won't follow the curves, but you can adjust the railing baseline to match the curves of the morph after you place it.
Versions 6.5 to 25
Hey, thank you! Do you know any reason as to why it wouldn’t show on the floor plan? Mine doesn’t, there are no graphic overrides, and I have tried arranging it to be on top.
Versions 6.5 to 25
Anais1
Thank you, the latter one worked:)
Didn't find the answer? Start a new discussion
Labels
