2022-01-15 05:13 AM
Does anyone know how to activate the support option for the Archicad 25 library solar panel objects? All 3 solar panel objects in the library have a greyed out option for "Support" under Style and Dimensions. Changing the criteria of number of panels etc. seems to have no effect and the option remains greyed out.
Solved! Go to Solution.
2022-01-15 07:09 AM
Once you change the angle to something other than zero, the box should become selectable.
2022-01-15 07:09 AM
2022-01-15 10:41 AM
Many thanks - as always- so simple!
